I used MGE2011, and the server was hang/not responding.
After check in MG error log file, I get this message:
"An exception occurred in DB XML component. Please try your operation later as the repository was busy"
How to resolve this error ?
Budianto
Hi!
I have this same error.
The Customer experiences constant crashes when using MapGuide Enterprise 2011 Service under Windows Senver 2003 32-bit; We ware able to re- run senver but after some time it crashed again. Using different web browsers, it took the MapGuide Enterprise 2011 Serivce, approx. 15 minutes to produce errors. Beforre that our Cutomer tested 60-day Trial version of MapGuide 2011 and there ware no problems. Since then there ware no changes made, despite the Map Guide Enterprise installation itself. lt looks like after reaching some maximum number of logged-in users the Service crashed.
Error: An exception occurred in DB XML component.
Error: Invalid argument
StackTrace:
- MgServer.open() line 1115 file d:\build\grandprix\build_53.5\ent\os\server\src\core\Server.cpp
- MgServiceManager.Initialize() line 145 file d:\Build\GrandPrix\BUILD_53.5\Ent\OS\Server\src\Common\Manager\ServiceManager.cpp
- MgServerResourceService.OpenRepositories() line 173 file d:\build\grandprix\build_53.5\ent\os\server\src\services\resource\ServerResourceService.cpp
- MgLibraryRepository.MgLibraryRepository() line 70 file d:\build\grandprix\build_53.5\ent\os\server\src\services\resource\LibraryRepository.cpp
- MgResourceContainer.MgResourceContainer() line 67 file d:\build\grandprix\build_53.5\ent\os\server\src\services\resource\ResourceContainer.cpp
