Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Edit Polyline Property in VBA
0 REPLIES 0
Message 1 of 1
Syrus1356
552 Views, 0 Replies
Hi
I have Several thousand Polyline
i define an Table named CODENOS and a field name ID typed character(From Map menu and select object data)
i want to select some of them and copy one property value to other like this
Sub test()
Dim SelOnScreen As AcadSelectionSet
Set SelOnScreen = ThisDrawing.SelectionSets.Add("b")
SelOnScreen.SelectOnScreen 'propmt user to select
' after selection, user must press Enter
For Each Item In SelOnScreen
If TypeOf Item Is AcadLWPolyline Then
Item.hyperlink.clear
Item.hyperlink.textToshow.value = Item.CODENOS.ID // pleaz write me a VBA code to do this
End If
Next
SelOnScreen.Delete
End Sub
0 REPLIES 0
