Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
.dwg layers to .sdf
0 REPLIES 0
Message 1 of 1
toyter
198 Views, 0 Replies
.dwg layers to .sdf
I'll re-ask a problem I can't get a grasp on and describe it better hoping for an answer. I have a drawing file that is in true scale. When I do a distance command on a side of a building that is 30 feet in real life, the distance command returns 30 feet. When I export the layers from this drawing to an .sdf file, MapGuide Author does not show layers (buildings). Do I need to scale down the .dwg prior to exporting? Will this make the .sdf display in Author?
0 REPLIES 0
