Hi all,
Generating a DWF file using MapGuide 2011 Enterprise causes the following exception:
Application name: iexplore.exe, version: 8.0.7600.16671
Module name: EPlotRenderer.dll, version: 11.0.0.86
Exception code: 0xc0000005
Error offset: 0x00056069
The code used for generating the DWF file is identical to the one use in the example “MG Utility Map” (plot.aspx)
The exception is thrown by the viewer installed as part of “Autodesk Design Review” ver . 11.0.0.86.
The exception occurs only when there are symbols on the map (represented by png images)
However works perfectly when there are only lines on the generated map.
Thanks in advance
