Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
DrawLine(); ..... ERROR
3 REPLIES 3
795 Views, 3 Replies
i am getting error while using redline function DrawLine().....
Invalid argument(s):
[1] = "LINESTRING XY (x0 y0, x1 y1)"
The AGF text is invalid because it failed to parse into a valid geometry object.
3 REPLIES 3
jumpinjackie
You need to replace x(0-1) and y(0-1) with the actual numerical values.
- Jackie
http://themapguyde.blogspot.com
http://au.linkedin.com/in/jackieng
Thanks for repliying me sir ,
i have solved that problem but now i am getting Error
--The specified file was not found:
%s
%s
FeatureClass
%s
%s
----------Even having that xml file in my folder.....
jumpinjackie
Are you trying to read/write an xml file, it could be you are specifying the content of the xml file and not the xml filename?
- Jackie
