Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Does AIMS support UCS setting?
1 REPLY 1
Cadbeyond
921 Views, 1 Reply
Hi
I would like to change the true north to specific angle! Can I do that? Thanks.
Eric
1 REPLY 1
gluckett
in reply to: Cadbeyond
That is a good question.  You will notice the rotation works great in the "Quick Plot" so why not the whole map?
I think when FUSION/Flexible Web Layouts move to OpenLayers 3.0 (http://ol3js.org/ol3/master/examples/rotation.html?q=rotate)
How I have done it in the past with MapGuide 6.5 and older was with the Oblique Stereographic Snyder Variation.
This has an asimuthal that you can use to rotate the map.  It works great - just change the coordinate system to the ones you need.
The trick is, creating the coordinate system (luckily AutoCAD Map 3D is a great tool for doing this).
gordon
