Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Dock Task Pane in Aqua Layout??
1 REPLY 1
emluv
473 Views, 1 Reply
I am using a MGE 2011 Fusion Aqua Layout and was curious to see if anyone has figured out a way to dock the floating task pane window?
Thanks!
emluv
1 REPLY 1
Daniel.Du
in reply to: emluv
Here is document about customizing Fusion viewer
Fusion Learning Materials for MapGuide
Hope it helps.
Daniel Du
Developer Technical Services
Autodesk Developer Network
