Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Display projection
3 REPLIES 3
702 Views, 3 Replies
Display projection
Hi All
Now I using a "WGS84.PseudoMercator (WGS84 based Mercator (spherical formulation))" projection and want to use another projection for displaying the coordinate of the status bar. How can I do that? I tried to use the "cursor position" script. It prompts the error! Even I use the same projection! Thanks.
Eric
3 REPLIES 3
The Display Projection should be EPSG:XXXX
Where XXXX is the EPSG code of the projection you want the coordinates to be displayed in
- Jackie
Got it! Thanks 🙂
foxeec
Hi,  I'm using AIMS 2013 and also looking to change the coordinates shown on the map from the WGS84.pseudo.mercator to our local coordinate system.  When looking at the picture attached by the OP, i notice that my 'CursorPosition' doesn't include the Display Projection (see attached).  Am i looking at the right widget?
thanks,
Lorrie
