I am doing MapGuide Authoring in Windows, and my MapGuide server runs on Linux. When i do the New data connection, first using FDO Provider for ODBC, i get this error "There is an error in XML document (0, 0). when trying to click on the Data Source name button. Thus i cannot proceed with the rest of the steps. The error in Test Connection Pane is "An exception occurred in FDO component.
RDBMS: No current open database."
When i tried to use the Configure Oracle Connection, either Use MapGuide credentials and Use the following credentials radio button do not get enabled; and when i hit Test Connection button, it returned this error message: "An exception occurred in FDO component.
CLNT_8_UNABLE_TO_LOAD_LIBRARY"
But when i test conection using the Mapguide server installed in Windows (same computer where i do MG authoring), the connection is successful. I can get the tables on my Oracle XE and even connect to my acess databases.
I checked in my installation directory, the FDO folder is present in "C:\Program Files\Autodesk\MapGuideEnterprise2007\Server\Bin" whereas in linux directory, FDO folder is not present in its server/bin directory. Does this makes the error?
I will greatly appreciate any help for this. Thank you.
