Infrastructure Map Server Developer
Active Member
nick_xu
Message 1 of 3 (1,298 Views)
Db::put: DB_LOG_BUFFER_FULL: In-memory log buffer is full
1298 Views, 2 Replies
10-25-2012 10:51 AM
Our map has more than 400 layers, and I see this errors very often from error log file:
Error: An exception occurred in DB component.
Db::smileytongue:ut: DB_LOG_BUFFER_FULL: In-memory log buffer is full
Is anyway to set DB_LOG_BUFFER.
we use AIMS 2012
Autodesk Infrastructure Map Server (Version 2.3.0.5801)
Autodesk Infrastructure Map Viewer (Version 2.3.0.5801)
I tried to reduce some layers and see less this error on log file.
Any solution?
thanks!
Nick
Valued Mentor
gluckett
Message 2 of 3 (1,256 Views)
Re: Db::put: DB_LOG_BUFFER_FULL: In-memory log buffer is full
10-31-2012 08:51 AM in reply to: nick_xu
In the serverconfig.ini in the BIN folder,  I have modified my LogBufferSizes:
SessionLogBufferSize = 20
LibraryLogBufferSize = 50
Active Member
nick_xu
Message 3 of 3 (1,252 Views)
10-31-2012 09:45 AM in reply to: gluckett
I'm using AIMS 2012 and can't find these 2 entries from serverconfig.ini
anything can be configured for these [DBEnvironmentProperties] for AIMS 2012?
thanks!
