Infrastructure Map Server Developer
Active Member
nick_xu
Message 1 of 2 (993 Views)
db_log_buffer_full error
993 Views, 1 Replies
10-30-2012 11:04 PM
Our map has more than 400 layers, and I see this errors very often from error log file:
Error: An exception occurred in DB component.
Db::smileytongue:ut: DB_LOG_BUFFER_FULL: In-memory log buffer is full
Is anyway to set DB_LOG_BUFFER.
we use AIMS 2012
Autodesk Infrastructure Map Server (Version 2.3.0.5801)
Autodesk Infrastructure Map Viewer (Version 2.3.0.5801)
I tried to reduce some layers and see less this error on log file.
Any solution?
thanks!
Nick
Board Manager
Daniel.Du
Message 2 of 2 (984 Views)
Re: db_log_buffer_full error
10-31-2012 10:33 PM in reply to: nick_xu
If you are using AIMS2013,  try changing (increase) the highlighted below -
[DBEnvironmentProperties]
# DB ENVIRONMENT
# This section is to set DB Environment. Determine the best sizes to improve the Server performance.
LibraryCacheSize                   = 32
SessionCacheSize                   = 2
DBPageSize                         = 32
DBXMLPageSize                      = 32
LibraryLogBufferSize               = 12
SessionLogBufferSize               = 1
DBMaxTransactions                  = 1000
SessionDBPageSize                  = 2
SessionDBXMLPageSize               = 0.5
DBTimeout                          = 0.2
DBMaxLockers                       = 1000
For AIMS 2012, you may need a upgrade, see this link : http://trac.osgeo.org/mapguide/ticket/1779
Daniel Du
Developer Technical Services
Autodesk Developer Network
