Our map has more than 400 layers, and I see this errors very often from error log file:
Error: An exception occurred in DB component.
Db:ut: DB_LOG_BUFFER_FULL: In-memory log buffer is full
Is anyway to set DB_LOG_BUFFER.
we use AIMS 2012
Autodesk Infrastructure Map Server (Version 2.3.0.5801)
Autodesk Infrastructure Map Viewer (Version 2.3.0.5801)
I tried to reduce some layers and see less this error on log file.
Any solution?
thanks!
Nick
If you are using AIMS2013, try changing (increase) the highlighted below -
[DBEnvironmentProperties]
# DB ENVIRONMENT
# This section is to set DB Environment. Determine the best sizes to improve the Server performance.
LibraryCacheSize = 32
SessionCacheSize = 2
DBPageSize = 32
DBXMLPageSize = 32
LibraryLogBufferSize = 12
SessionLogBufferSize = 1
DBMaxTransactions = 1000
SessionDBPageSize = 2
SessionDBXMLPageSize = 0.5
DBTimeout = 0.2
DBMaxLockers = 1000
For AIMS 2012, you may need a upgrade, see this link : http://trac.osgeo.org/mapguide/ticket/1779
