Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Data is being scaled
1 REPLY 1
mjfarrell
336 Views, 1 Reply
From Infrastructure studio, after I connect the feature source
in the form of a SHP file
and create a layer definition
Add that layer to a MAp
and Publish to Web
The data is somehow being scaled; image the state of Texas is now onyl 2 meters wide!?!
Has anyone seen this?
Importing the same data inot MAP 3D shows that the information is correct prior to any coordinate transformation being done by studio.
1 REPLY 1
jackie.ng
in reply to: mjfarrell
Does your SHP file have a .prj file attached? Does your published Map Definition's coordinate system match what you are expecting?
- Jackie
