Infrastructure Map Server Developer
Active Contributor
emluv
Message 1 of 4 (701 Views)
Custom Logo in Fusion Print Layout??
701 Views, 3 Replies
03-22-2011 12:07 PM
I was wondering if anyone knows if it possible to add a custom logo in a print layout in a Fusion map? I have read that it is possible using Ajax or DWF viewers, I am just having a hard time finding out how to achieve this in Fusion. Please help:smileyhappy:
Thanks in advance!!
emluv
Active Member
janechii
Message 2 of 4 (686 Views)
Re: Custom Logo in Fusion Print Layout??
03-23-2011 08:07 AM in reply to: emluv
Take a look at fusion "Print" widget where you installed the webserverextensions.
.../webserverextensions/www/fusion/widgets/Print/
There's a file "printablepage.templ" which contains the HTML for the printout. You can modify this to put in your custom logo.
Hope this helps!
Valued Mentor
gluckett
Message 3 of 4 (657 Views)
04-10-2011 09:39 AM in reply to: janechii
Check out the Watermarking in AIMS 2012 (next version of MapGuide) - it is great for tagging all your maps with your corporate logo.
gordon
Board Manager
Daniel.Du
Message 4 of 4 (551 Views)
08-10-2011 04:02 AM in reply to: gluckett
Agree with gordon about  the watermark of AIMS 2012 :smileyhappy:
Check it out in the following webcast:
Video : Autodesk® Infrastructure Map Server 2012 API Webcast
Recorded version of the Autodesk® Infrastructure Map Server 2012 API webcast
View online | Download
Daniel Du
Developer Technical Services
Autodesk Developer Network
