i was able to configure the sample sheboygan data in Studio and access it via the browser but when i try to import our existing DWG files into Studio i get this generic error message:
"Attempted to read or write protected memory. This is often an indication that other memory is corrupt"
I am trying to load the data by dragging and dropping it from a windows explorer into the left pane of Studio.
A google search points me at various Visual Studio programming issues that can trigger this error message, but i havent begun any development yet. the server is running Windows Server 2008 R2 64bit.
Solved by tmblackflag. Go to Solution.
turns out the DWG file was corrupt. Tried a different one and it worked.
