Infrastructure Map Server General Discussion
Valued Contributor
swimming123
Message 1 of 1 (474 Views)
Create a map image for Fusion
474 Views, 0 Replies
11-09-2012 08:05 AM
When I use API to create a map image, I use the MgRenderingService. If you use fusion, then I found pass paramters of extent is just create a data scale (not the view extent) and image is not same with your zoom level; So we need to pass map center coordinates, scale parameters to create a map image which is same with the view of your map. Share this information.
