Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
could not select any object into my layer
4 REPLIES 4
jane911
1538 Views, 4 Replies
Hi ,
I'a developping an apllication with autodesk mapguide entreprise 2010 and sql server2008.
mydataconnection come from sql viewer so i couldn't selct any feature into my layer .
please help
4 REPLIES 4
websoft
in reply to: jane911
Jane,
A few questions, is this a SQL Spatial database?  Also, I'm not sure what is the problem, are you not able to see any features in your map or are you not able to select them but you can see them.
Manoj
LoriBerry
I am also having issues with selecting features that have been loaded up from a spatial database (SQL Server 2008). Is this a limitation to Mapguide Enterprise?
jackie.ng
in reply to: LoriBerry
It's more a limitation of views.
Can MapGuide detect the identity properties from your view?
Because: No identity properties = unselectable layer
If that is the case, you have either re-consider the design of your view or to employ using a FDO schema override to say that [this column in this view is unique so use that as the identity property]
http://themapguyde.blogspot.com/2010/08/using-fdo-schema-overrides.html
http://themapguyde.blogspot.com/2010/09/using-fdo-schema-overrides-redux.html
- Jackie
Darrellolson
in reply to: jackie.ng
Finally I found the solution to my problem. Thanks for sharing
