Hi
I installed first visual studio 2010, then installed AIMS2013 in a directory out of Program Files, followed all the instructions in http://download.autodesk.com/media/adn/AIMS2012_Webcast_English/AIMS2012_Webcast_English.html but didn't work. If netframework for web aplication is 3.5 i get could not load mapguidedotnetapi earlier time error, i f i change to framework 4 i get could not load mapguidedotnetapi format incorrect. AIMS2013Pool is configured to netframework 4 and 32 bits false.
I tried to find the solution in forums and internet, tried a lot of things but none work.
Could anyone tell me some clue or link, thank you, kind regards and happy new year
If you followed the webcast but not succeeded, there may be some problem about the installation. Would you please check this post to check whether the installation is correct?
AIMS2013 uses .net framework 4.0.
You said that "install in a directory out of Program Files," is it permission problem? I have no idea only by this information, just guessing....
Hi Daniel
I can work perfectly in windows 7 32 bits, at this moment i'm installing on windows 7 64 bits to try if this is a problem on windows 2008 r2 64 Bits or if its a problem with 64 bits in general, i will post in a few hours the result of this installation
Thank you
Salvador Biot
