Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Constant size Redline Symbol
4 REPLIES 4
339 Views, 4 Replies
Dear Developers,
I have a problem. I create a redline layer dynamicaly from my program, then I add new Symbols to the Layer.
How Can I make this symbols "Constant size" like I can do it with the predefined layers? Or I always have to check them at every zoom and Remove them and create it with the new calculated size?
I hope there is a much more easier way only I don't know about it. Please tell me how you use to solve this problem.
Best Regardes
Vajdaur
4 REPLIES 4
Vajdaur,
Unfortunately any redline symbols you add to the map through the api will
behave in this manner, such that they grow bigger or smaller as you zoom in
or out. Your other option is to add the symbols to the map by using the
dynamic authoring toolkit and the api's support for the AddMapLayer()
method. I have done this before, so I can at least tell you that it will
work.
To do this you would setup a routine on your server application that
receives the parameters for the redline symbols to add to the map (such as
the x/y location, name, etc.). Based on these parameters you would build a
dynamic map layer (.mlf) which you would then have to stream back the the
user's map. It's not a simple solution, but in the end it is much better
functionality than having to resize all of your redline symbols upon each
map view change.
Navid
"vajdaur" wrote in message
news:f1a4725.-1@WebX.maYIadrTaRb...
Dear Developers,
Best Regardes
Vajdaur
I don't think that is true
I think I actually did this a while back
With the viewer API I believe you can set symbol(point elements) height,
width etc. using MGSymbolAttr object (setHeight, setWidth).
Refer to the viewer api help.
I'm not sure if I still have an example of how I did this. Plus I did it in
VBScript so I'm not sure how much help it would really be is fou are using
JavaScript(which I am not personally real fond of) but hey that's just me
Bob
"Navid Falconer" wrote in message
news:B90ED9FD034B9B4FF7363AD17A78E09B@in.WebX.maYIadrTaRb...
> Vajdaur,
in
> work.
a
> map view change.
> Navid
> Dear Developers,
then
> Best Regardes
> Vajdaur
I checked the Autodesk Developer Network website. It also says that it is
not possible to create redlines whose text and sizes don't change with map
scale (document id: 66029) .
If it's just symbols that you need to create, and you have the dynamic
authoring toolkit, I'd recommend my first solution in the previous post.
However, if you need to create other redline objects as well (lines,
polygons, etc) then the storing and recreation upon scale change is probably
a better option.
Navid
"Bob Cassarly" wrote in message
news:04CF0380C0644CC48ADD45CF51E77637@in.WebX.maYIadrTaRb...
in
> Bob
> > Vajdaur,
will
> in
will
> > work.
as
build
> a
the
better
each
> > map view change.
> > Navid
> > Dear Developers,
> then
Remove
Please
> > Best Regardes
> > Vajdaur
I trying to set up such a solution with the "Dynamical Authoring Toolkit" but have some problems making it work. Do you have any good example code how you did it. In other case I how some questions to specify my problems:
1, I tried to use the "WriteToMlf"-function, to save the redline layer as a mlf-file on the server through the DAT API without any success. It does not seams to work for "Redline" layers. What key functions did you use to get the redline layer to the server?
2, How do you make the layer "constant size"? Is the layer stored as an mlf-file and is the size recalculated before the redrawn in the map?
I would really appreciate a response! A good solution to this problem would really be useful!
/Goran
