I checked the Autodesk Developer Network website. It also says that it is
not possible to create redlines whose text and sizes don't change with map
scale (document id: 66029) .
If it's just symbols that you need to create, and you have the dynamic
authoring toolkit, I'd recommend my first solution in the previous post.
However, if you need to create other redline objects as well (lines,
polygons, etc) then the storing and recreation upon scale change is probably
a better option.
Navid
"Bob Cassarly" wrote in message
news:04CF0380C0644CC48ADD45CF51E77637@in.WebX.maYIadrTaRb...
> I don't think that is true
> I think I actually did this a while back
> With the viewer API I believe you can set symbol(point elements) height,
> width etc. using MGSymbolAttr object (setHeight, setWidth).
> Refer to the viewer api help.
> I'm not sure if I still have an example of how I did this. Plus I did it
in
> VBScript so I'm not sure how much help it would really be is fou are using
> JavaScript(which I am not personally real fond of) but hey that's just me
> Bob
> "Navid Falconer" wrote in message
> news:B90ED9FD034B9B4FF7363AD17A78E09B@in.WebX.maYIadrTaRb...
> > Vajdaur,
> > Unfortunately any redline symbols you add to the map through the api
will
> > behave in this manner, such that they grow bigger or smaller as you zoom
> in
> > or out. Your other option is to add the symbols to the map by using the
> > dynamic authoring toolkit and the api's support for the AddMapLayer()
> > method. I have done this before, so I can at least tell you that it
will
> > work.
> > To do this you would setup a routine on your server application that
> > receives the parameters for the redline symbols to add to the map (such
as
> > the x/y location, name, etc.). Based on these parameters you would
build
> a
> > dynamic map layer (.mlf) which you would then have to stream back the
the
> > user's map. It's not a simple solution, but in the end it is much
better
> > functionality than having to resize all of your redline symbols upon
each
> > map view change.
> > Navid
> > "vajdaur" wrote in message
> > news:f1a4725.-1@WebX.maYIadrTaRb...
> > Dear Developers,
> > I have a problem. I create a redline layer dynamicaly from my program,
> then
> > I add new Symbols to the Layer.
> > How Can I make this symbols "Constant size" like I can do it with the
> > predefined layers? Or I always have to check them at every zoom and
Remove
> > them and create it with the new calculated size?
> > I hope there is a much more easier way only I don't know about it.
Please
> > tell me how you use to solve this problem.
> > Best Regardes
> > Vajdaur
