Infrastructure Map Server General Discussion
s.klein
Message 1 of 5 (490 Views)
Connecting to PostGIS 2.0
490 Views, 4 Replies
01-26-2012 07:35 AM
i want to connect the AIMS 2012 to a PostgreSQL-DB with PostGIS 2.0 installed.
In Autodesk Infrastructure Studio i'm able to make a data connection so that the schema shows up in the preview.
When i create a layer, no geometry is shown up in the preview...
With Desktop-GIS like ArcMap or QGIS i can establish a connection without problems, so i think geometry columns are right in PostgreSQL 8.4/PostGIS 2.0.
Has anybody solved a problem like that yet?
SK
Valued Mentor
jackie.ng
Message 2 of 5 (482 Views)
Re: Connecting to PostGIS 2.0
01-26-2012 05:43 PM in reply to: s.klein
The FDO provider that comes with AIMS 2012 does not support PostGIS 2.0
- Jackie
s.klein
Message 3 of 5 (478 Views)
01-26-2012 10:43 PM in reply to: jackie.ng
sorry to hear that...
will fdo support postgis 2.0 in the nearer future?
Active Member
pian2000
Message 4 of 5 (429 Views)
03-19-2012 01:16 AM in reply to: s.klein
when you make the data connect can you view the attribute? and also when ceating for layer are you able to select the field?
s.klein
Message 5 of 5 (426 Views)
03-19-2012 02:41 AM in reply to: s.klein
yes, i'm able to view the attributes and i can select the different attributes creating a layer... but the layer doesn't show up in the preview or weblayout. with postgis 1.5.3 it's working well.. i think aims can't handle the geometry cause it's stored in postgis 2.0 on an other way then in 1.5.3 and fdo doesn't support the postgis 2.0 geometry yet...
