Infrastructure Map Server General Discussion
mfernandes
Message 1 of 4 (1,499 Views)
connecting to an access database (mapserver 2013)
1499 Views, 3 Replies
07-26-2012 10:16 AM
I am following the exact steps in connecting to an access database
http://wikihelp.autodesk.com/Infr._Map_Server/enu/2013/Help/0001-Getting_0/0016-Exercise16/0023-Conn...
and I get the following error when I test connection
An exception occurred in FDO component. RDBMS: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified.
Mapserver 2013, on Windows 7/64, I have the MS access 64 drivers installed.
any help is appreciated.
Valued Mentor
jackie.ng
Message 2 of 4 (1,495 Views)
Re: connecting to an access database (mapserver 2013)
07-26-2012 06:17 PM in reply to: mfernandes
Microsoft Access Driver (*.mdb) is the 32-bit driver
Microsoft Access Driver (*.mdb, *.accdb) is the 64-bit driver
There should be a choice to pick between the two. It should be the second one.
- Jackie
mfernandes
Message 3 of 4 (1,487 Views)
07-27-2012 09:55 AM in reply to: mfernandes
Brilliant:smileyvery-happy:
If I can now choose between the 32bit and 64 bit drivers,
does this mean that 64bit Map3D, Civil3D and Map server can now connect to MS office 32bit.
or do I still need to follow the proccess as outlined here
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18307898&linkID=9240697
to install the MS 64bit drivers.
Valued Mentor
jackie.ng
Message 4 of 4 (1,480 Views)
07-30-2012 06:54 PM in reply to: mfernandes
Your AutoCAD variant must use the Microsoft Access driver of the same bitness.
- Jackie
