I am trying to connect to a SQL Server Spatial datasource in Autodesk Infrastructure Studio 2012. I can connect to the datasource and the test connection is ok. However when I open the data source the feature class is empty with a warning. Would anyone be able to help resolve this issue? Thanks
If your SQL Server database has no tables with geometry/geography columns, then you can't actually create any layers from that database.
You should also check if your specified user has permission to access the tables you were expecting to see in the Feature Class list.
- Jackie
Thanks for your help. I think it is a permisson issue as I have tried to connect to the database via FDO toolbox and an error is displayed that I am unable to access the system database 'model'. I will try and contact the DBA.
Thanks to you both for replying. If I log on with SA I do not have this issue and all the tables are visible. I am, however, not the database administrator (it is a corporate mapping dataset) and I am not sure how comfortable they will be in issuing a permanent log on with such a high level of permission. Do you know if there is a work around for this? Thanks
In my experience, i have my DBA give me all permissions when i first connect to the SQL Server, then after I'm connected, he'll start locking down my permissions until i have only the tables i need.
Lorrie
I am also experiencing the same connection problems in Autodesk Map3D 2013. My IT department are really reluctant to increase my permissions without further information although I have demonstrated in both applications that logging in with sa solves the connection problems. Would anyone be able to provide details of the bug in AIMS? Thanks.
I am using Studio 2012 and can't make a connection to any sql instances.
I installed a local sql express 2008 that I have permissions to all data tables and still can't connect.
The error is:
An exception occurred in FDO component.
RDBMS: [Microsoft][ODBC SQL Server Driver][DBNETLIB]SQL Server does not exist or access denied.
[Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen (Connect()).
Any help would be greatly appreciated.
Just wanted to say thanks for your suggestion. I haven't replied as I still haven't received permission from our IT department to download the dll files, hopefully I will be able to test your suggestion soon.
Hi Carto,
SQl is a headache, but surmountable.
Try this:
1. Grant Select acces to all graphic tables in the catalog
USER [databaseName]
GO
GRANT SELECT ON schemaName.tableName TO userName; -- do this foreach table GO
USE [databaseName] GO ALTER AUTHORIZATION ON SCHEMA::[schemaName] TO [userName] GO
3. Change user to owner of database
USE [databaseName] GO EXEC sp_addrolemember N'db_owner', N'userName' GO EXEC sp_addrolemember N'db_ddladmin', N'userName' GO
4. Set public access to MASTER database
use [master] GO GRANT SELECT TO PUBLIC GO GRANT SELECT TO userName GO
set this permission foreach database in the tree of SQL Server
if you do not get prior permission, then user MapGuide Maestro (it's most powerfull than infrastructure studio), and open database connection as XML and edit
download here: http://trac.osgeo.org/mapguide/wiki/maestro
and do this:
Thanks again for your help but I am still not having any luck gaining permission to change anything in the corporate SQL server settings. I did try editing the XML in Maestro as you suggested but can I just double check should I be entering 'Master' as the value?
Hi, I am trying to connect to some OS Mastermap tables which do have spatial data. The problem is that I am connecting via a user which does not have full dbo permissions and I am just trying to find a work around without getting full dbo rights as my IT department are reluctant to grant them.
My personal suggestion, move the tables to another different database of "MASTER" master is a proprietary database for SQL SERVER, should only be used by the DBMS. Is not strange that IT does not give you permission on this database.
Have doubts about how to create a new database? ..
Sorry I think I have confused you the tables are not in the database called master they are in a test database environment I just don't have the correct permissions to access them, I will keep trying. Thanks again for your help.
Hi, it was just to give a quick update. I finally managed to connect to SQL Server data in AIMS 2012 (without having sa admin permissions) by creating views to the database tables owned by my user and not the dataowner. Thanks again for all your help and suggestions.
