Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Connect to ArcSDE
0 REPLIES 0
Message 1 of 1
nik.mazreen
488 Views, 0 Replies
Connect to ArcSDE
Hi..
I’m trying to connect data from Mapguide Studio Ent. 2011 and I already follow all the steps which I should follow without success. The step as follows;
http://gisexchange.typepad.com/blog/2010/11/adding-the-arcsde-provider-to-the-data-connect-dialog-in...
I’m trying for a week without success and therefore, I’m seeking for your advice about this matters and hopefully can resolve this issue. The detail about the conf. as attached. Thank you.
FYI: The ArcSDE I try to connect using  9.3.1 version 32 bit and SQL server 2008 32 bit.
Snap From MGE 2011
Configuration in C:/system32/drivers/etc/services
Sde.dll, pe.dll and sg.dll 64 Bit Version in FDO/Bin
-Nik-
0 REPLIES 0
