I run into problem with composite lines:
I have an SHP dataset. I tried to create a layer with themes and composite lines and I run into this:
http://discussion.autodesk.com/forums/thread.jspa?messageID=5965310
So I switched to SDF, I loaded my SHP files into SDF format with a load procedure and I got similar, but a bit worse result. So I decided to throw away the themes, and decided to create separate layer for every theme. I imported the SHP-s into DWG with AutoCAD Map, created separate AutoCAD layers by queries, and loaded the DWG into SDF with a load procedure. So I have separate layers based on an SDF datasource, I don't have to use themes.
I'd like to use composite lines, but the the rendering of the composite lines from this SDF layer looks very bad, I can see the startpoint and the endpoint of the line segments. In an SHP layer the rendering of the linework was continous.
Is there any workaround of this problem?
Szabolcs
