Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Commercial Layers do not match up when zoomed in
7 REPLIES 7
Message 1 of 8
391 Views, 7 Replies
I am encountering a problem when zoomed in with commercial layers. The commercial layers to not resize or match up with my map. In other words, things are not where they are supposed to be.
Has anybody else had this issue? Is therd a work around?
7 REPLIES 7
Message 2 of 8
For the Google maps, you may see the "Birds eye" view when zooming in.  That is not fixed yet in AIMS, but there is a work-around.
In the fusionSF-compressed.js (back up first!)
Search for
streetViewControl:false});
Replace it with
streetViewControl:false});mapObject.setTilt(0);
There is no guarentee that your data will match anyway (yours might be way more accurate!).  By any chance, are you storing you data in Lat/Long or a State Plane coordinate system?
Message 3 of 8
My map is in WGS84.PseudoMercator. The issue I have is when I am zoomed in closer than 1:1150.
I will try you work around shortly. For our area of interest, Bing tends to have better images so thats what most users go for. For us, Google is sort of a back up plan.
Message 4 of 8
This is the closest thing I can find.
streetViewControl:!1}),this.enableTilt||a.setTilt(0)
Message 5 of 8
This is my fusionSF-compressed.js   With a txt extension
Message 6 of 8
gluckett
What version of AIMS are you running? 2014?
Message 7 of 8
in reply to: gluckett
2015. in 2014 the commercial layers disapeared when zooming in that close.
Message 8 of 8
gluckett
Yes, the application in 2015 has a bug that does not stop your zooming below the standard External Providers.
You could put a check scale function to turn off the google layers etc if you are below 1,500 scale etc...but it would take a little code.
