Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
changing value of symbole library
0 REPLIES 0
Message 1 of 1
582 Views, 0 Replies
hi,i developping a site web with asp.net and mapguide entreprise 2010 ,i could refreh my layer programetecly with DOM but i could'nt change the image of symbole library . could any body help me .
the code of modification layer is setting below :
      XmlDocument EmpXMLDoc2 = new XmlDocument();
       string XMLDocPath2 = Server.MapPath("symbole.LayerDefinition.XML");
          EmpXMLDoc2.Load(XMLDocPath2);
          XmlNode node4;
          node4 = EmpXMLDoc2.DocumentElement;
          string h3 = null;
          string nom = "";
      int nbr=node4.ChildNodes.Count;
          foreach (XmlNode node2 in node4.ChildNodes)
//            Object xmlAddSymbolDoc;
// xmlAddSymbolDoc = Server.CreateObject("Microsoft.XMLDOM");
//xmlAddSymbolDoc..async = False
             // string hh = node2.ChildNodes[6].ChildNodes
              //XmlNodeList hk = node2.ChildNodes[6].ChildNodes;
             // string j = hk.Item(0).Name;
              //string hb = hk.Item(0).ChildNodes[2].ChildNodes[1].ChildNodes[0].ChildNodes[7].ChildNodes[1].Name;
             // hk.Item(0).ChildNodes[2].ChildNodes[1].ChildNodes[0].ChildNodes[7].ChildNodes[1].InnerText ="s14";
                  EmpXMLDoc2.Save(Server.MapPath("symbole.LayerDefinition.XML"));
          string xml3 = String.Format(GetTemplate("symbole.LayerDefinition.xml"), nom);
         string h4 = SaveSessionResource("symboles.LayerDefinition", xml3, resourceService, sessionId);
0 REPLIES 0
