Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Change settings for MapGuide Viewer 6
1 REPLY 1
175 Views, 1 Reply
Hi
Is it possible to program the MG Viewer 6 settings (the ActiveX Control). We have an application that requires the selection mode in the Viewer to be Intersection (and not Centroid) and the Map Units to be Metric (and not USA Units).
Best regards
RS Jensen
1 REPLY 1
Hello
  You can use MGMap.SetSelectionMode(string
mode) method to set the selection mode to "Intersecton".
Unfortunately, there is no API method to change the display units. You can
change it in the popup menu. R
igh click the
viewer or Author to bring out the popup menu, Select help-> preferences, then
the preferences dialogue box will show up. You can change the display units
there.
Haiyun
Hi
Units).
Best regards
RS Jensen
