hi all,
as i need to get the map image
and pass it to the mobile.i must add the push pin layer to the map programmatically without user interaction. which means, once the image map being prompted to the user, the push pin should be there. i have try to figure out how it can be done..but it give me no luck.
anyway, i have try to perform all the step of adding the push pin manually.but i don't know whether it is correct or not..i try to get the map image by using the session generated in the file but it gave me such error message:
"Resource was not found: Session:29f8009c-0000-1000-8000-0013722ed36b_en//SG Map.Selection
Resource was not found: Session:29f8009c-0000-1000-8000-0013722ed36b_en//SG Map.Selection Exception occurred in method MgResourceDefinitionManager.GetDocument at line 476 in file c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourceDefinitionManager.cpp "
i have attach my code and i hope somebody can help me out...
thanx a lot...
regards,
Kencana
