Hi everyone,
I'm trying to create and use a custom print layout in Infrastructure Studio 2015 using the basic web layout.
I've created the print layout and I'm following the instructions here to create a printable page:
http://help.autodesk.com/view/AIMS/2015/ENU/?guid=GUID-32E2B0EC-13F7-4B8A-9E9E-5EE46994E8D9
The trouble is when I go to 'Add Command', 'Get Printable Page' isn't listed under 'Built-In Command'.
Any help is much appreciated!
Solved by gluckett. Go to Solution.
Help is incorrect. Get Printable Page is now just the Quick Plot in the Basic Web Layout - the Print Layouts don't do anything anymore.
The reason I was looking at the 'get printable page' function was to be able to change the background colour of the map while plotting. Is this possible with Quick Plots? I cannot find any information indicating it is. Thanks again for your help!
In the C:\Program Files\Autodesk\Autodesk Infrastructure Web Server Extension 2015\www\mapviewerphp\quickplotgeneratepicture.php
You could hard-code the color your wish to plot the background with - around line 102:
$colorString = $map->GetBackgroundColor();
// The returned color string is in AARRGGBB format. But the constructor of MgColor needs a string in RRGGBBAA format
$colorString = substr($colorString, 2, 6) . substr($colorString, 0, 2);
$color = new MgColor($colorString);
just comment out the $color line with two forward slashes:
//$color = new MgColor($colorString);
and add a RRGGBBAA format - this example is lime green background.
$color = new MgColor('b9edafff');
If you don't know how to generate the RRGGBBAA format, click the 3rd colour picker on this site:
http://peteroupc.github.io/colorpicker/
"Alpha Color Picker (RRGGBBAA format)"
regards
gordon
