Im having problem login to infrastructure studio, got this error --> cannot connect to the specified url.
all the services related is running. also can go to site administrator but cannot login also, got error --> cannot establish connection.
dont no what else to check.
need help asap.
thanks in advance
-nick-
Solved by santos.bravo. Go to Solution.
Solved by hence_the_name. Go to Solution.
the message it quite common. Have you checked the MG OS mailing list archives for a solution?
http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
Just guessing - firewall?
Rob
The server and web extensions are in the same machine?... if they are in separated machines, maybe you have a problem with the ports (firewall or port number not the same).
hello..
it has been awhile..finally the problem solved.
I go thru back the installation process and I realize that I have not set the correct setting in the server configuration during the installation because I install map server and web extension in 2 different server.
and i also check the firewall and enable the ports used by aims.
Thank you for your time and support. 🙂
-nick-
