Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Can't get tooltip to work in a flexible web layout
1 REPLY 1
tony.witham
905 Views, 1 Reply
I'm using AIMS 2014.  I have created a tooltip for a layer (the tooltip simply consists of one of the properties).  The tooltips display correctly if I view my map in a Basic Layout.  When I view the same map using a Flexible Layout the tooltips do not display.
Can anyone help?
Tags (1)
1 REPLY 1
tony.witham
in reply to: tony.witham
Eureka!  Found the cause of the problem (quite by accident - no skill on my part).
The flexible web layout that I was using did not have the Maptip component loaded in any of the containers.  As soon as I added Maptip to one of the menus, the tooltips worked fine.
It would appear that the option to retrieve information about features is Disabled by default if Maptip is not present, and is Enabled by default if Maptip is present.
Tags (1)
