Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Can I create a point layer from web service
1 REPLY 1
429 Views, 1 Reply
Hi All I would like to use data from a web service to display the lat,long of a point The web service has new points added on a weekly basis, so i would like to use the live web service that outputs in xml i think Is this possible to do in studio or do i have to script the layer Any help would be appreciated to direct me in the correct location Thanks Greg
1 REPLY 1
gluckett
If you want to consume XML from a web service. You would be best to use the Fusion aka Flexible Web Layout client.
This client uses the OpenLayers engine and that can consume all sorts of data (KML, XML, JSON).
