Infrastructure Map Server General Discussion
Valued Contributor
swimming123
Message 1 of 4 (584 Views)
Can I change ApplicationDefinition based on log in client's Id
584 Views, 3 Replies
11-06-2012 10:37 AM
In order to show different spatial data type to different clients; Can I dynamically (program) to create a fusion Application Definition? I really need this function works.
Valued Mentor
jackie.ng
Message 2 of 4 (579 Views)
Re: Can I change ApplicationDefinition based on log in client's Id
11-06-2012 06:41 PM in reply to: swimming123
An ApplicationDefinition is just an XML document pointed to by a resource id.
Both of which you can customize and/or override before the Fusion viewer ever gets its hands on it.
So you would build the specific ApplicationDefinition XML document based on your client's id, save it out into a session-based resource id, and feed that resource id into your Fusion template URL so it gets initialized with your client-specific ApplicationDefinition
- Jackie
Valued Contributor
swimming123
Message 3 of 4 (577 Views)
11-06-2012 07:26 PM in reply to: jackie.ng
Thank you very much, Jackie.
Valued Contributor
swimming123
Message 4 of 4 (568 Views)
11-07-2012 07:56 AM in reply to: jackie.ng
It's a very good idea. But I cannot find the where is the fusion Application Definition file stored, or where is my layout folder is when I create it using Studio or Maestro. Thank you.
