I can confirm on what both of you said about the problem and the way for
getting rid of it.
Besides, it is slow to retrieve the Oracle objects available under an
existing Oracle schema and populate them in the Show tables grid. In my
case, there are about 270 tables, views and materialized views under my
Oracle native schema, and each time for the database connection, it takes
3-5 minutes for retrieving the available objects and reverse engineering the
existing/foreign Oracle schema. I wonder why the MGE server can not cache
the connection and schema metadata properly, so that the reverse engineering
process doesn't have to be run from scratch each time?
Meng
wrote in message news:5688623@discussion.autodesk.com...
I was able to stop the repeat sequence by hitting cancel, click on a new row
using the gray grid column to select an alternate row (not using the
mousewheel) then I was able to scroll. The new row should highlight blue
indicating it was selected. It almost appears that focus is not removed from
the key field cell and the mousewheel triggers the action which brings the
popup.
Dave
