Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
bounding box and liteview
2 REPLIES 2
159 Views, 2 Replies
I have liteview installed and the sample application works fine. However,when
I try to view my own mwf the map is blank. I am sure it is a problem with the bounding box values.
I took the center lat long values of our map and created a rectangle around it to get the box values.
We use NAD 83 CA coordinate system when authoring our mwf , is that a problem?
The numbers I used for the bbox are 37.41,-122.19,37.47,-122.10
Any clues??
Thanks!
2 REPLIES 2
try 37.41,-122.10,37.47,-122.19
Thomas
leiyongjun
Hi, The bounding box coordinate must be in the same coordinate system as what you served the data in your mwf. For example, if you use State Plane coordinates, you must use the state plane coordinates instead of latitude/longitude for your bounding box value.
Hope this helps.
Yongjun Lei ylei@vbgov.com
