Infrastructure Map Server General Discussion
Valued Contributor
swimming123
Message 1 of 2 (407 Views)
Base Layers for Smooth Navigation in Fusion Viewer?
407 Views, 1 Replies
09-12-2012 09:40 AM
I noticed AIMS2013 has the function of Base Layers for Smooth Navigation in Ajax Viewer. Is it also works for Fusion Viewer?  Thank you.
Valued Mentor
jackie.ng
Message 2 of 2 (404 Views)
Re: Base Layers for Smooth Navigation in Fusion Viewer?
09-12-2012 08:13 PM in reply to: swimming123
Yes, as of AIMS2013 Fusion will now properly display maps with tiled and untiled layers.
In previous releases it was an either-or situation in Fusion. Either all your layers are tiled or they were untiled. It couldn't be both. This is no longer the case for AIMS2013
- Jackie
