Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Automatic Query and Filter of any Layer
9 REPLIES 9
Message 1 of 10
384 Views, 9 Replies
There is now an online demo of IME's Generic MapGuide Query Filter.
http://www.ime-gis.co.uk/demos/sqlquery/
This collection of scripts allows you to automatically filter any map layer
and report on them without having to write a single line of code.
It will apply to any layer which has an associated database (unless you deny
access to the layer set up from within the MWF).
As you add more layers in future it will automatically pick them up and
handle them in the same way.
You can download the archive (including full instructions) from here :
http://www.ime-gis.co.uk/support/download/gmqf.zip
The best thing is, the encrypted version is free to use and distribute. If
you wany the open source version give us a call.
Regards
Alan Douglas
9 REPLIES 9
Message 2 of 10
Give a look at
05C6EA9A1960544A8B9A8CA5EF782000@in.WebX.maYIadrTaRb
Regards
Pierre
"Alan Douglas" a écrit dans le message news:
49B91527B7BDE1D38E93277C289E9C1E@in.WebX.maYIadrTaRb...
layer
deny
If
> Regards
> Alan Douglas
Message 3 of 10
Pierre,
What is: 05C6EA9A1960544A8B9A8CA5EF782000@in.WebX.maYIadrTaRb ??
Regards
Alan
"Pierre Cardinal" wrote in message
news:5E18F47ED7BDEAD5E4326122C8BE0747@in.WebX.maYIadrTaRb...
> Hi,
> Give a look at
> Regards
> Pierre
> layer
> deny
> If
> > Regards
> > Alan Douglas
Message 4 of 10
Alan -
The number string is the ID for a message on the discussion
group. Here is the information.
Anne Brown
Manager, Moderator
Autodesk Product Support Discussion Groups
Discussion Q&A: http://www.autodesk.com/discussion
Marion Pietsch (Autodesk)
Thursday, January 31, 2002 11:52 AM
Re: SDF files on a remote computer
Pavel,
run the MapGuide Server service as user account (control panel >
services >
MapGuide Server 6.0 > Startup) and enter a user that is also
known on the
machine where the SDF files are stored.
Marion Pietsch
GIS Product Support, EMEA
"Pavel Pomezny" wrote in message
news:AF28AFE2439AEA7EDC0CA02DA6CFB437@in.WebX.maYIadrTaRb...
> Hi,
> I'd like to create new map layer but the data source (SDF files) are on a
> different computer.
> When I specifying path for SDF files on a different computer and use the
> universal naming convention (UNC) or mapped this computer to a drive
letter,
> I cannot create new map layer because I don't see the SDF files in a map
> layer properties.
> I would like to know where is problem.
> Thanks
> Pavel
Alan Douglas wrote:
> Pierre,
Message 5 of 10
I note this requires OLE BD datasets to be registered by Cold Fusion. Does this mean we cannot use MSAccess datasets
which are currently using ODBC?
gavan
Message 6 of 10
Gavan,
ColdFusion can easily be set-up to use OLE DB
connections to Access.
From the CF admin pages there are links to both
ODBC (you don't have to go through the Windows control panel) and OLE DB
connection set-ups.
There are two things to remember;
 1) CF does not by default set the OLE DB
driver to Jet 4, if you have the latest jet drivers / Win 2k change the
"Microsoft.Jet.OLEDB.3.51" to "Microsoft.Jet.OLEDB.4.0"
 2) You must manually set "Admin" as the
username (no password) when connecting to a default Access
database
We strongly recommend OLE DB over
ODBC.
  Crispin
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
gavan
Message 7 of 10
Currently i am working on creating a Layer filter task using Mapguide Enterprise 2009 in .NET platform
Does the sample mentioned below suits my need?
if so, Please give me the right link to obtain the sample code as the given link could not be opened.
Ram
Message 8 of 10
hi
I am unable to view the link http://www.ime-gis.co.uk/demos/sqlquery/
that you have posted.
Kindly give me the link to view in to the application.
thanking you,
regards,
Teja.
Message 9 of 10
Hi Alan,
I am not able to acces the links. Is there any other way to access the site?
Could u pls help.
Binny
Message 10 of 10
Hi Alan,
Could u pls help.
Binny
