Show only
Search instead for
This is what I have, isn't it the same?
"barryk" wrote in message
news:13108452.1073245551268.JavaMail.jive@jiveforum1...
> You can add the automatic download ability for IE in the tag:
codebase="ftp://adeskftp.autodesk.com/WebPub/mapguide/ver6/mgaxctrl.cab#Vers
ion=6,0,3,3">
> Barry Kelly
> GeoSpatial Web Services
> www.geospatialweb.com
Assuming you have all the installation information in the same directory as
your web site data then it is possible. If this is an Intranet only
application, you are probably best to create your own ftp site for your
internal viewers. It is a little tidier than dumping all of the files with
your application.
Barry Kelly
http://www.geospatialweb.com
"Robert J." wrote in message
news:3ff9ea6c$1_2@statler...
CLASSID="CLSID:62789780-B744-11D0-986B-00609731A21D"CODEBASE="mgaxctrl.cab"
> WIDTH=100% HEIGHT=100% ID="Map">
> > classid="CLSID:62789780-B744-11D0-986B-00609731A21D"
> ion=6,0,3,3">
> > Barry Kelly
I'm not sure if the formatting of the message caused this, but the problem
may be that there is no space between the end of your CLASSID and CODEBASE
parameters. I'm not sure if this would cause it to fail. As Barry said,
make sure that the MGAXCTRL.CAB file resides in the root of whatever web
site your map is in if you don't want to use FTP.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.spatialgis.com
> ion=6,0,3,3">
> > Barry Kelly
