Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Autodesk Mapguide 2009 1.5GB memory limitation
0 REPLIES 0
Message 1 of 1
isaacyey
238 Views, 0 Replies
I'm using Autodesk Mapguide 2009 Enterprise version to pre-populate tilecaches offline with metatile turn on.
Autodesk will then complaint "out of memory" error when I set the metatile too big, I noticed that it will only hit peak memory usage < 1.5GB.
Any suggestion on this to increase mapguide server memory usage? Thanks much!!!
0 REPLIES 0
