Infrastructure Map Server Developer
New Member
isaacyey
Message 1 of 1 (82 Views)
Autodesk Mapguide 2009 1.5GB memory limitation
82 Views, 0 Replies
02-10-2009 11:49 PM
I'm using Autodesk Mapguide 2009 Enterprise version to pre-populate tilecaches offline with metatile turn on.
Autodesk will then complaint "out of memory" error when I set the metatile too big, I noticed that it will only hit peak memory usage < 1.5GB.
Any suggestion on this to increase mapguide server memory usage? Thanks much!!!
Post to the Community
New Post
Need installation help?
