We are working on upgrading from 2013 to 2015 on our server. I read the other day that 2015 does not support IE11. Over half our systems at my location have already been upgraded to IE11. Is this going to be fixed soon or is it an un-fixable issue? If it is not fixable then there is no need for us to upgrade to 2015.
Kristy
Just as an anecdote, the AJAX and Fusion viewers work fine on my IE11.
What you may be "hearing" is that IE11 is not in the matrix of officially supported browsers for AIMS 2015. Another way of saying: IE11 may or may not work for this release. If it does, great. If it doesn't, support won't be able to help you.
If you want to remove any doubt, install an evaluation copy of AIMS 2015 (http://www.autodesk.com/products/infrastructure-map-server/free-trial) on a test machine or disposable VM and you can find out for yourself.
- Jackie
