Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Autodesk Infrastructure Map Server 2012 on 64 bit
2 REPLIES 2
IAtika
1703 Views, 2 Replies
Hi everyone,
I am trying to run Autodesk Infrastructure Map Server 2012 on 64 bit Windows 7. Everything installs perfectly without any error , but when i try to login on administration login page with the default user "Administrator" , & password "admin" ..it says wrong password. same issue from the Studio, it is not allowing me to login ... same with the mapagent ...the main page appears but when I give credentials it simply gives an error. I reinstalled, checked all the logs, congif's ..still can't pinpoint what's going on.
I am using the bundleded installer of the trial with java as the development language. It has configured java before install, confirmed it a number of times, tomcat working fine ...anyone have any idea where & how I can troubleshoot further? I have attached the exact errors.
Thanks in advance,
Atika
2 REPLIES 2
larisa12
in reply to: IAtika
Hello, I just installed IMS 2012 and have similar problem trying to connect to Site Administrator. Did you have it resolved? I would really uppreciate the assistance. v/r, Larisa
jackie.ng
in reply to: IAtika
Have you tried restarting the Apache Web Server?
- Jackie
