Infrastructure Map Server Developer
New Member
IAtika
Message 1 of 3 (1,431 Views)
Autodesk Infrastructure Map Server 2012 on 64 bit
1431 Views, 2 Replies
05-08-2012 03:40 AM
Hi everyone,
I am trying to run Autodesk Infrastructure Map Server 2012 on 64 bit Windows 7. Everything installs perfectly without any error , but when i try to login on administration login page with the default user "Administrator" , & password "admin" ..it says wrong password. same issue from the Studio, it is not allowing me to login ... same with the mapagent ...the main page appears but when I give credentials it simply gives an error. I reinstalled, checked all the logs, congif's ..still can't pinpoint what's going on.
I am using the bundleded installer of the trial with java as the development language. It has configured java before install, confirmed it a number of times, tomcat working fine ...anyone have any idea where & how I can troubleshoot further? I have attached the exact errors.
Thanks in advance,
Atika
New Member
larisa12
Message 2 of 3 (1,345 Views)
Re: Autodesk Infrastructure Map Server 2012 on 64 bit
07-02-2012 08:30 AM in reply to: IAtika
Hello, I just installed IMS 2012 and have similar problem trying to connect to Site Administrator. Did you have it resolved? I would really uppreciate the assistance. v/r, Larisa
Valued Mentor
jackie.ng
Message 3 of 3 (1,325 Views)
07-08-2012 08:00 PM in reply to: IAtika
Have you tried restarting the Apache Web Server?
- Jackie
