Hi everyone,
I am trying to run Autodesk Infrastructure Map Server 2012 on 64 bit Windows 7. Everything installs perfectly without any error , but when i try to login on administration login page with the default user "Administrator" , & password "admin" ..it says wrong password. same issue from the Studio, it is not allowing me to login ... same with the mapagent ...the main page appears but when I give credentials it simply gives an error. I reinstalled, checked all the logs, congif's ..still can't pinpoint what's going on.
I am using the bundleded installer of the trial with java as the development language. It has configured java before install, confirmed it a number of times, tomcat working fine ...anyone have any idea where & how I can troubleshoot further? I have attached the exact errors.
Thanks in advance,
Atika
Hello, I just installed IMS 2012 and have similar problem trying to connect to Site Administrator. Did you have it resolved? I would really uppreciate the assistance. v/r, Larisa
