Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
Any way to use ESRI Geodatabases in MapGuide?
3 REPLIES 3
315 Views, 3 Replies
probably an obvious question, as I guess only SHP and SDE can be used.
3 REPLIES 3
You are correct. I was searching the same option, coz we deal with gdb & @ the moment, there is no such feature at all in mapguide, if you comeacross any answer for this please lete me also know.
The GDAL provider supports personal geodatabases - getting the right
configuration parameter is tricky but possible through an ODBC connection to
the file...
Crispin _at_ 1Spatial
wrote in message news:6007938@discussion.autodesk.com...
Is there any place that explains how to do this?
I would like to use the personal geodatabase I have, but I'm not having much luck figuring out how to make it work in MapGuide (Enterprise 2009).
