molly_t52@hotmail.com wrote:
> I have two Questions - 1. I need to tile a big tiff image into smaller
> images. I used FME - Raster Tiler to do that. However it changed the
> color and the resolution Is there any tool within mapguide to generate
> tiles? 2. I use Raster Workshop to create RIC - raster image catalog
> file. When I click Add To end to add the file, it says 'Adding file
> references' and then it just crashes. And then i get error - Memory
> could not be read. I tried minimizing the size tiles etc. but it didnt
> work. Pl help Thanks a lot Molly
You may be able to use an open source utility called GDAL to do that.
http://www.gdal.org/
You can download a full Windows package that includes GDAL and a bunch
of other useful stuff as part of FWTools:
http://fwtools.maptools.org/
A MapGuide 6.x RIC is just a text file containing a list of files with
their bounding coordinates. This is moderately easy to build using FME
to directly read the image bounds, or you could use another GDAL tool
gdaltindex) to generate a shapefile with the extents of your images, and
run that through FME.
Not that if you're doing this for MapGuide Enterprise, it doesn't read
RICs; it uses an XML-based config file to store the image boundaries.
Jason
