Infrastructure Map Server General Discussion
Valued Contributor
swimming123
Message 1 of 4 (777 Views)
AIMS2013 Scale issue
777 Views, 3 Replies
11-27-2012 09:45 AM
I found that scale values show in the map always not in integer, and even worse, when I try to type in 50000, it automatically change to some wierd value like 41246.2638. I didn't use cache and BaseLayerGroup in my map. How to fix this?
Valued Mentor
gluckett
Message 2 of 4 (708 Views)
Re: AIMS2013 Scale issue
12-11-2012 05:45 PM in reply to: swimming123
If you are using Spherical Mercator and Google, Bing, etc, you are stuck with the industry scales.
Valued Contributor
swimming123
Message 3 of 4 (691 Views)
12-13-2012 08:22 AM in reply to: gluckett
Actually I have my own arthophoto image plus my several hundred of vector layers, So I don't use google map or Bing map.
My current solution for scale is applying a factor to my pdf map. For example actally map scale is 251234.1234, then I apply the factor of 251234.1234/250000 when I create a pdf,so I can write 1:250000 on the pdf, pdf size is specially for Letter, Legal and Ledger 3 choices. If I can draw a scale bar on the pdf then I don't need care about the scale value and paper size.
Valued Mentor
jackie.ng
Message 4 of 4 (685 Views)
12-13-2012 07:08 PM in reply to: swimming123
Extending Gordon's answer: If your map has tiled layers, your scales will always snap to the nearest finite scale in your Map Definition. That's probably what that strange looking number is. It's probably one of those finite scales.
- Jackie
