Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
AIMS Fusion Widget Listeners
1 REPLY 1
santos.bravo
529 Views, 1 Reply
I need detect when the user activate a widget, exist an option to do this?   like
widget.on("click", function(){
   alert('Hi....');
Tags (1)
1 REPLY 1
jackie.ng
in reply to: santos.bravo
Widgets only expose an event that is raised when it is enabled/disabled.
But, any widget that has a toolbar/menu representation also has a uiObj property that represents the UI button/menuitem the widget is attached to.
So this should work:
widget.uiObj.addEvent("click", function() {
    alert("You clicked me");
 - Jackie
