Infrastructure Map Server Forum
Welcome to Autodesk’s Infrastructure Map Server Forums. Share your knowledge, ask questions, and explore popular Infrastructure Map Server topics.
AIMs 2015 Fusion missing buttons
6 REPLIES 6
frosty1_4me
399 Views, 6 Replies
More bugs to the 2015 release.  In the fusion version, the aqua template specifically our users (myself included) are experiencing missing button icons on the left nav menu.  I can't find what's causing this.   The buttons that are visible are also not activating the correct function within the map.
6 REPLIES 6
gluckett
in reply to: frosty1_4me
I have found that I have to add the meta tag for Internet Explorer at the top of the index.html page in the MapGuide Fusion Templates (i.e. Aqua)
<meta http-equiv="X-UA-Compatible" content="IE=10">
Note: This metatag may also have to be in the same page where the iFrame is located.
frosty1_4me
in reply to: gluckett
We currently use <meta http-equiv="X-UA-Compatible" content="IE=EDGE"> in our main load page and it's also in the aqua index file page.
I have implemented the change you suggested without success unfortunately.
gluckett
You may want to try the content="IE=10" rather than EDGE...
frosty1_4me
I did that, same result.  Unless It's cached and hadn't refreshed properly.   I'll leave it in there for a while and see if anything changes.  Clearing the cache doesn't always seem to produce immediate results.
Does IE developer tools (hit F12 before loading) report any errors?
- Jackie
frosty1_4me
Hey Jackie,
No, there are no errors reported.  I've also tested in FF and Chrome which work fine its just an issue with IE.
